LaraDryden's avatar
LaraDryden
Follower
Oct 18, 2022
Can Orbi and Network Work
I have up and running the Orbi AC3000 Tri Band Wifi Router. I also have a Netgeqr AC2200 Tri-Band WiFi Range Extender (EX7700). Do they work together? Should I get rid of the Netgeqr?
1 Reply
  • plemans's avatar
    They don't integrate but they can work together.
    You setup your orbi and then just install the ex7700 using the installation assistant.
    It just connects the extenders backhaul to the orbi's fronthaul.
