MartinUK
Aug 15, 2007Aspirant
Can the DG834GT router be used as a repeater?
Hi all, Sky supplied me with a DG834GT router when I took their broadband package. Trouble is that I already had one of these routers which is now sitting there unused. The wireless network doesn...
Tyrone_Flyrone
Aug 15, 2007Novice
Welcome to the forum.
Some of the Netgear routers are being upgraded for WDS. You will need to check the latest firmware version for the DG834GT. If it has support for WDS, you can get the setup to work. Without WDS, the other access point or router will have to be wired into the DG834GT. So the setup will not work.
Peace
Peace
