MartinUK
Aug 15, 2007Aspirant
Can the DG834GT router be used as a repeater?
Hi all, Sky supplied me with a DG834GT router when I took their broadband package. Trouble is that I already had one of these routers which is now sitting there unused. The wireless network doesn...
MartinUK
How can I check to see if it supports WDS? Assuming that both routers support WDS and that I can get them upgraded if necessary (how do I do this?) what then is the procedure for setting up the second router to lock into the signal of the first?
Thanks for your help
Martin
Martin
