MartinUK
Aug 15, 2007Aspirant
Can the DG834GT router be used as a repeater?
Hi all, Sky supplied me with a DG834GT router when I took their broadband package. Trouble is that I already had one of these routers which is now sitting there unused. The wireless network doesn...
s0uthpaw
Aug 16, 2007Aspirant
Check the Feature list of the latest firmware online. Otherwise:
Upgrade your device's firmware by downloading the appropriate firmware from www.netgear.co.uk/product_support.php
Install by logging in to your router via http, and select "Router Upgrade" or some such option.
Once your router is upgraded, if it supports WDS it will have an "Advanced Wireless Settings" option within the web interface.
I would warn you that setting up a wireless bridge is not for the faint of heart. While it seems straightforward in theory, it can be heartbreaking (personal experience).
