MartinUK
Aug 15, 2007Aspirant
Can the DG834GT router be used as a repeater?
Hi all,
Sky supplied me with a DG834GT router when I took their broadband package. Trouble is that I already had one of these routers which is now sitting there unused. The wireless network doesn't cover the whole house. Downstairs we are getting 10% signal strength on the PS3.
I realise we could do with a repeater. Question - can I use the spare DG834GT somehow or do I have to buy something else? If so does it have to be something like the WG602 or could it be any make, eg Linksys or Belkin?
Thanks in advance
Martin
Thanks in advance
Martin
- DannzNoviceI'm using a pair of DG834N's with one as access point and the second as repeater. The set up seems to work ok. The configuration is detailed in the thread called 'DG834N as repeater'. The drawbacks are having to use WEP rather than WAP and slower b&g rather than n.
- vincentieoAspirantHi, after a lot of googling and a call the the tech department at netgear i learned this:
- No, it is not possible. Both devices in the bridge (WDS network) must have WDS mode (wireless bridging and repeating)
- if only one has this mode then it will not work without a wired connection (which defeats the point)
HOWEVER, make sure you have the model number correct because only the DG834GT in the DG834... series does not have this mode.
- DG834G v.2
- DG834G v.3
- DG834G v.4
- DG834G v.5
Will all work as they have WDS mode options.
(on a side note dd-wrt - open source firm ware for routers - is not supported by the entire - DG834G series so dont even bother looking.
I know this is an old post but someone will surely google onto it in the future so it is nice to have a definite answer. - jmizoguchiVirtuosoDG team has the firmware for DGXX
btw, this is 3years old thread.
