MagicJer
Jul 13, 2021Follower
Can the Nighthawk EX7300 be used as a wifi router?
I own a Nighthawk Model EX7300 and was hoping the wirelessly connect it to my WiFi modem (which is in a closet near our kitchen) to extend the range throughout our condo (which has concrete walls) bu...
Jul 15, 2021Guru - Experienced User
Will it act as a router? no.
can you connect it and put the EX7300 in access point mode? Yes. That'll should achieve what you're trying to do. The actiontec is a simple moca adapter so is still running off the router in the other room. So by connecting the EX7300 to it and putting it in access point mode,it'll should work
