Confusedpapa
Mar 25, 2020Aspirant
Can wn2000rptv3 be connected by Ethernet as an input source
I am trying to increase the range for WiFi. Is there a way to hard wire, via Ethernet cable, so I can then increase the distance of my WiFi. If I use just the wireless _EXT, I don’t get any signal....
Mar 25, 2020Guru - Experienced User
Page 14 of the manual walks you through placing it in Access point mode. This enables you to hardwire it in.
find the manual, firmware, and install directions here
- ConfusedpapaMar 26, 2020Aspirant
Thank you for the info, much appreciated!
