PatDofNJ
Nov 23, 2021Aspirant
Can you mix AC1750 WiFi Mesh Extender with powerline devices
Can a AC1750 WiFi Mesh Extender be used on a home network that also uses Powerline 200 and Powerline 500 devices?
michaelkenward
Nov 24, 2021Guru - Experienced User
The only device in the Netgear armoury that seems to follow the AC1750 wifi standard and work as a Mesh device is the EX6250.
This does have the ability to work as a WiFi access point.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Install your extender in access point mode.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
