lbellkna
Sep 06, 2013Novice
Can you modify the _EXT name?
Good Morning, I am new to the forums and hope I can word this question in a manner that everyone understands. I was able to install my WiFi Booster for Mobile WN1000RP with limited problems. I used...
WizardJ
Oct 18, 2013Luminary
Make sure you are connected to the extender wirelessly, or via cable, and simply visit http://www.mywifiext.com/ alternatively http://www.mywifiext.net/. For all the wireless products you should be able to use "admin" and "password" to login if prompted for credentials. Then go to Setup > Wireless Settings and change the name in "Name (SSID)" and click "Apply". However, I would really advice you to contact NETGEAR for troubleshooting or further guidance. Have a look at Contact Support. :)
