zenkus
Jan 06, 2020Follower
Cannot access admin panel for R6220 router configured as Access Point
Hello, I've got a simple home setup with 2 R6220 routers, one as the main router and the other configured as an access point (which is a refurbished device). I'm trying to update firmware on both => ...
Jan 06, 2020Guru - Experienced User
Here's how I'd start. I'd also try multiple broswers or pc/s as sometimes it can be a browser issue.
1. unplug the routers from each other.
2. Then try broswing to the routerlogin website on the one you want to update.
3. If that doesn't work, see if the assigned IP address or default works.
4. worst case, reset it, update it, and reconfigure. Luckily since its in ap mode, there's not much to change on it.
