AtomG
Sep 28, 2012Aspirant
Cannot access N300 configuration
Our notebook computer which is fairly new and downstairs from our wireless dsl modem began having connectivity problems. Since the router is fairly old, I decided to install a new wireless access poin...
AtomG
Sep 29, 2012Aspirant
jmizoguchi wrote: N300 is NOT access point
N300 is NOT model #
N300 is N router
belongs to
http://forum1.netgear.com/forumdisplay.php?f=33
Sorry about the incorrect title; I now see that it's really a WNR2000. I'll briefly describe what I did to get it working.
1. I did a factory reset on the WNR2000 and hooked it directly to a computer using one of the LAN ports. I was able to login using the default login ip.
2. I changed the WiFi to channel 11 because my other is on channel 6.
3. I set the ipa to 192.168.1.253 and disabled DHCP. I saved this and powered it off.
4. Then I logged into my dsl modem and changed its DHCP range from this (192.168.1.1 to 192.168.1.253) to this (192.168.1.1 to 192.168.1.252).
5. I connected my dsl modem/router to LAN1 of the WNR2000 and one of my computers to LAN2 of the WNR2000.
6. I powered up the WNR2000 and everything worked.
I don't know if this is all exactly right, but it works.
