Waldoctg
Jan 18, 2014Novice
Cannot access NETGEAR WG602 Control Panel
Hey All, I cannot access my NETGEAR WG602 (wireless router)'s control panel. It is connected to the modem though a wired-router (Dynex DX-E402), and when I type in the IP address for the WG602 it ...
jmizoguchi
Jan 19, 2014Virtuoso
You probably did it setup different IP
Remove the WG unit , directly connect to the PC ans uses static IP on PC and try access and fix the issues or reset and setup again
