Waldoctg
Jan 18, 2014Novice
Cannot access NETGEAR WG602 Control Panel
Hey All, I cannot access my NETGEAR WG602 (wireless router)'s control panel. It is connected to the modem though a wired-router (Dynex DX-E402), and when I type in the IP address for the WG602 it ...
Waldoctg
Jun 23, 2014Novice
You said...
The problem is if I connect the Netgear wireless router directly to the ethernet cable, it will not be long enough to reach where I need it to be upstairs... with this being said, can I still have the Netgear wireless router connected to the modem through the Dynex wired router and access the cPanel of Netgear wireless router?
Here's a diagram:
[Modem] -> [Dynex wired router] -> [Netgear wireless router]
jmizoguchi wrote:
Remove the WG unit , directly connect to the PC ans uses static IP on PC and try access and fix the issues or reset and setup again
Here's a diagram:
