Waldoctg
Jan 18, 2014Novice
Cannot access NETGEAR WG602 Control Panel
Hey All, I cannot access my NETGEAR WG602 (wireless router)'s control panel. It is connected to the modem though a wired-router (Dynex DX-E402), and when I type in the IP address for the WG602 it ...
Waldoctg
Jun 30, 2014Novice
Hmm...
I tried this, but no dice.
I set the Dynex router to no DHCP, and the IP to 192.168.1.100... The problem I run into is when I try to access the Netgear WG602 access point.
I used this pdf to try to set it up, but it wasn't connecting... I even plugged directly into the access point. Is there a reason why?
http://www.downloads.netgear.com/files/WG602v4_IG_04June07.pdf
