Waldoctg
Jan 18, 2014Novice
Cannot access NETGEAR WG602 Control Panel
Hey All, I cannot access my NETGEAR WG602 (wireless router)'s control panel. It is connected to the modem though a wired-router (Dynex DX-E402), and when I type in the IP address for the WG602 it ...
jmizoguchi
Jun 30, 2014Virtuoso
I even plugged directly into the access point. Is there a reason why?
http://www.downloads.netgear.com/fil...G_04June07.pdf
If you have directly connected the the WG602 with same lan subnet range on PC with static IP you should able to access the GUI.
