Waldoctg
Jan 18, 2014Novice
Cannot access NETGEAR WG602 Control Panel
Hey All, I cannot access my NETGEAR WG602 (wireless router)'s control panel. It is connected to the modem though a wired-router (Dynex DX-E402), and when I type in the IP address for the WG602 it ...
Waldoctg
Jul 06, 2014Novice
This doesn't work... when I set the Dynex router to DHCP mode off, then it stops its connection and no signal goes through the ethernet line. I power cycled both routers and did everything they stated (except for the wireless parts of course).
I am connected directly to the Dynex router through ethernet. Once I get this connection going through ethernet, then I was going to plug in the access point and configure that.
Any tips?
Any tips?
