Waldoctg
Jan 18, 2014Novice
Cannot access NETGEAR WG602 Control Panel
Hey All, I cannot access my NETGEAR WG602 (wireless router)'s control panel. It is connected to the modem though a wired-router (Dynex DX-E402), and when I type in the IP address for the WG602 it ...
Waldoctg
Jul 06, 2014Novice
I did this part " Click the ADVANCED tab and select Setup > LAN.
In the IP Address field, change the LAN IP address of the router to 192.168.1.100 (same IP segment of the main router, 192.168.1.1) and clear the Use Router as DHCP server check box."
After that, the main router's IP address changed and it stopped working all together. I power cycled it, but to no avail...
Any ideas?
Any ideas?
