Waldoctg
Jan 18, 2014Novice
Cannot access NETGEAR WG602 Control Panel
Hey All, I cannot access my NETGEAR WG602 (wireless router)'s control panel. It is connected to the modem though a wired-router (Dynex DX-E402), and when I type in the IP address for the WG602 it ...
Waldoctg
Jul 14, 2014Novice
UPDATE: so I used the late layout for the router and then connected the access point to that and it works!
However, I have noticed the range of the main router isn't as far... is that because the access router is now attached?
I also changed the channel on the router ... maybe this would effect the length of the range of it?
