broglet
Apr 01, 2022Star
cannot access WN2000RPT setup wizard from Windows 10 pc
It was working perfectly until today then suddenly it stopped connecting to my router. My phone connects to the WN2000RPT but it says "connected no internet". My phone connects to my router with go...
- Apr 02, 2022
that's not correct. When you're setting up the extender, the device you're using to set it up with (the pc) should ONLY be connected to the extender. either via wifi or ethernet. It should not be connected to the router or it defaults back to that connection.
broglet
Apr 01, 2022Star
Thanks for your reply plemans
Yes - I held the paperclip in for a good 30 seconds.
The central green led first turned steady orange then it flashed regularly orange until I released the paperclip. Then it went out completely for several seconds. Then it came on steady orange. Then after several more seconds it reverted to steady green.
Apr 01, 2022Guru - Experienced User
according to the led's, its booted up normally.
If you do a wireless scan after the reboot do you see the netgear_ext ssid?
WN2000RPTv1 | Universal WiFi Range Extender | NETGEAR Support
- brogletApr 01, 2022Star
Yes I see "NETGEAR_EXT Internet not available"
- plemansApr 01, 2022Guru - Experienced User
connect to that and go to mywifiext . net
I can’t access www.mywifiext.net; what do I do? | Answer | NETGEAR Support
This is the first thing I tried to do (please see my first post in this thread)
When I so it I get a NETGEAR page that says "You are not connected to your extender's WiFi network"
