broglet
Apr 01, 2022Star
cannot access WN2000RPT setup wizard from Windows 10 pc
It was working perfectly until today then suddenly it stopped connecting to my router. My phone connects to the WN2000RPT but it says "connected no internet". My phone connects to my router with go...
- Apr 02, 2022
that's not correct. When you're setting up the extender, the device you're using to set it up with (the pc) should ONLY be connected to the extender. either via wifi or ethernet. It should not be connected to the router or it defaults back to that connection.
