Tallman's avatar
Sep 05, 2026
Cannot Change Channel on EX6120
I have a NETGEAR EX6120 WIFI extender that I have been using for six months now.  By default, both bands use the same channels that my router is using.  I have been trying to change the channels of b...
  • schumaku's avatar
    Sep 05, 2026
    Exactly. Thats the way it is with most WiFi Range Extender designs: These always operate on the same channel set like the primary router, basically because there is only one radio adapter taking care of two jobs: talk to the main router and listen/send data to your phone or laptop.
