SPlatten
Feb 09, 2020Guide
Cannot connect , password not accepted
I purchased an AC1200 Dual Band WiFi Range Extender. I followed the instructions as per the Quick Start guide and I have solid green lights on Power, Router and WPS LED's. On my iMAC I can see...
- Feb 11, 2020
Just making sure its clear as I re-read mine and was a bit confused :)
If you haven't set it up yet, the wireless ssid/password should be printed on the device. Use that to connect to the extender and then go through the setup process. You can custom set the ssid/password for the extender while going through the setup process.
SPlatten
Feb 11, 2020Guide
Thanks will try when I get home tonight.
Feb 11, 2020Guru - Experienced User
- SPlattenFeb 13, 2020Guide
All sorted now.
- Mskinner32Feb 17, 2020AspirantWhat was your solution because im having the exact same issue!
- SPlattenFeb 17, 2020GuideAs pointed out in one of the posts the initial connection details are printed on the device (sticker on the back). It would have been so helpful if this information on where to look was included in the leaflet that ships with the device.
