axelorn
Aug 07, 2021Aspirant
Cannot connect devices to my WiFi extender (AC750)
Hello, I have just bought a AC750 WiFi range extender (Model EX 3110). I have managed to connect it to the router so that now the extender shows a green light where it says: Power, Router and WPS as ...
Aug 07, 2021Guru - Experienced User
did you set it up using wps?
If so, try a factory reset and install it using the installation assistant and not wps.
Not all routers code wps the same (they should) and it can cause issues.
what router are you connecting it to?
