Cindihughes
May 14, 2023Follower
Cannot connect extender
Cannot connect to Spectrum router
May 15, 2023Guru - Experienced User
What router model?
What extender model?
What firmware is on the extender?
What method of setup are you using?
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
