D823D
Nov 16, 2023Aspirant
Cannot connect my Netgear EAX12 extender to my Netgear RAX10 router.
michaelkenward
Nov 17, 2023Guru - Experienced User
And?
Blank messages are always a bad sign. There isn't enough room to cram everything into the subject.
What are you doing and what goes wrong?
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
D823D
Nov 17, 2023Aspirant
The router and extender are both new. I’ve tried setting up the extender per the manual and the Netgear_ext does not show up in my available networks to connect to. I’ve also connected my extender to my router with Ethernet line with no success. When I tried using network map with the Nighthawk router app to manage the extender and my router password is not recognized when I try using the app.
- michaelkenwardNov 17, 2023Guru - Experienced User
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.- D823DNov 17, 2023AspirantIt is a modem only.
DPC3216-VCM-K9 DOCSIS 3.0 16x4 Cable Modem
- plemansNov 17, 2023Guru - Experienced User
Did you try setting up the extender with wps? If so, it wont' show with a separate ssid as its a mesh extender.
It'll use the exact same.
And if you hardwired in the extender as your one post implies,you'd need to re-run setup in access point mode for it to work that way.
So did you try the click button wps method of setup?
- D823DNov 17, 2023AspirantNo I did not use the wps method. I’ve tried it in the past with other extenders with unreliable results.
