D823D
Nov 17, 2023Aspirant
Cannot connect my Netgear EAX12 extender to my Netgear RAX10 router.
Nov 17, 2023Guru - Experienced User
Did you try setting up the extender with wps? If so, it wont' show with a separate ssid as its a mesh extender.
It'll use the exact same.
And if you hardwired in the extender as your one post implies,you'd need to re-run setup in access point mode for it to work that way.
So did you try the click button wps method of setup?
D823D
Nov 18, 2023Aspirant
No I did not use the wps method. I’ve tried it in the past with other extenders with unreliable results.
