ben1982
Aug 28, 2020Initiate
cannot connect password not accepted
I am unable to connect to the _Ext option as the password is not accepted. I have followed the set up instructions for the extension device, connected via wifi and have a solid green light for the WPS. I do not have a 2g or 5g EXT option when searching for available broadband options, but do have a _Ext version of my broadband...It does not accept my password however. I have reset the password to be sure. I saw some previous posts suggesting that there should be a password on the bottom of the device but mine does not have one. There is a WPS pin but I have tried that and it does not work either. Would be very grateful for any advice.
Thanks
Glad to hear you got it working! If you mark it solved, it might help the next person with this issue
What router are you connecting to?
What extender is it? You didn't put your model.
What firmware is on the extender?
Try factory resetting the extender and then reinstalling it using the installation assistant and NOT WPS.
WPS can get coded different between manufacturers and cause issues.
The extender (if factory reset) shoudl't require a password to connect to it for the initiall connection/setup.
