jeffreyctf
Aug 02, 2020Follower
Cannot connect RAX40 with extender EAX20
Hi all, i just purchased the wifi extender EAX20, aim to improve the coverage of my router RAX40 I cannot setup the connection between them by mobile app, as it keep saying that my wifi passw...
silveronetrx
Aug 06, 2020Aspirant
I also have this same problem. Has anyone tried to downgrade the firmware and confirmed that it solves the problem?
MarichalEric
Aug 08, 2020Initiate
Yes. Once you downgrade your RAX40 router to firmware 1.0.3.64, the extender will be begin to function if you had already set it up. If you haven’t set up your extender yet it will function and not give you the “wrong password” error. It works!
