MB100
May 15, 2020Tutor
Cannot connect to http:// www. mywifiext. net/
Hi Hope someone can help, I am definately connected to my range extender but keep getting the error message saying I am not or cannot connect. Actual message says "You are not connected to your exte...
- May 15, 2020
If you log into whichever router you have, you should be able to find the attached devices page (or equivalent). Find the ip address for the extender and use that to connect to it.
May 15, 2020Guru - Experienced User
MB100
May 15, 2020Tutor
Thanks for your reply. Once I have the IP address do i just type that into my web browser address bar?
