bpaver
Oct 09, 2011Follower
Cannot connect Wii to WN3000RP
Hello,
The laptops in the area can all use the WN3000RP to connect. But I cannot get the Wii to connect. The Wii gives an error each and every time we try to set up the connection. The Wii can see the range extender and shows the correct name, and a "green" symbol to say that the signal is good, but then will not connect. We get 52130 and 52030 both having to do with no internet connection. Does anyone have any idea what I am doing incorrectly?
Thank you
Thank you
1 Reply
- jmizoguchiVirtuosowhat encryption type did you set on extender ?
