EllisW
Jul 23, 2020Follower
Cannot Continue after installing Extender and connecting
Having struggled through the connection process and finally installed 2G and 5G EXT networks via the Extender, I'm at the page that says, "Click the Continue button after you connect your WiFi device...
Jul 23, 2020Guru - Experienced User
It usually means connecting the device you're on (doing the setup) to the extender.
The EX6120 has an ethernet port. I find it simpler, faster, and easier to run setup by connecting that route. Just disable the wifi on whatever device you connect that route so it doesn't default back to the wireless connection.
