JonWill
Sep 19, 2011Aspirant
Cannot enter admin on WG102
I have been using a WG102 access point for several years. Now one of my wireless devices is struggling to connect. It has been suggested that there may be a channel conflict with a neighbouring wire...
JonWill
Oct 04, 2011Aspirant
Finally solved this (sorry for the delay in getting back!)
Angry IP scanner showed not IP addresses active in that range. However I found another thread that you had contributed to
http://forum1.netgear.com/showthread.php?t=51531
That sorted it - I needed to give my PC a static IP address in the same range as the router in order to access it. I have now been able to change the WAP to the correct range and can now see it on my network.
Thanks for the help!
J
J
