Michael_
Jan 18, 2012Novice
Cannot find KEY to allow access to other PCs
Help... I have a MAC and NETGEAR was set up using the MAC... I now am trying to gain access with a PC onto NETGEAR. It is having trouble "Validating Identity". As such, I've checked out some ...
jmizoguchi
Jan 18, 2012Virtuoso
pc or mac has NOTHING to do with the issues
login the router and you may need to adjust the wireless setting.
make sure the computer which are accessing the router is WIRED to the router when changing the wireless settings
