Michael_
Jan 18, 2012Novice
Cannot find KEY to allow access to other PCs
Help... I have a MAC and NETGEAR was set up using the MAC... I now am trying to gain access with a PC onto NETGEAR. It is having trouble "Validating Identity". As such, I've checked out some ...
Susie23
Jan 19, 2012Aspirant
Re: Cannot find KEY to allow access to other PCs
pc or mac has NOTHING to do with the issues
login the router and you may need to adjust the wireless setting.
make sure the computer which are accessing the router is WIRED to the router when changing the wireless settings
Correct me if im wrong... I believe you are using an old Mac - which doesnt support WPA.
Just access the GUI of the router and take note of the "Key 1".
On your Mac, use the Key 1 code. (put a $ sign at the end of the code if it is not working.)
