wrinklycodger
Sep 04, 2013Novice
Cannot find PIN to install signal booster
My daughter has bought a wireless signal booster to extend the range of her DG834G Netgear Router. We have spent hours following forum advice on how to find the router's PIN which is not shown on the ...
wrinklycodger
Sep 05, 2013Novice
Thank you both. On forums I read that the PIN should be found, having enteredthe router's control software, a username and password in (I think) an Advanced tab but it isn't there.
Is there another way to 'start again' with the router and set it up in a way to enable the booster? As you can tell this is not my expertise.
