lilymichelle98
Jan 01, 2023Follower
cannot get wifi password to my wifi mesh extender ac1900 dual band
I was given a wifi extender recently, I can't get the password when trying to it set up, i already factory reset. and used the app...and maybe it's a glitch but It wouldn't copy the password on my app...
Jan 02, 2023Guru - Experienced User
Did you set it up using the push button WPS option?
Or if you tried the app, I'd start over and use the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
