Sjorrit
Mar 15, 2022Tutor
Cannot login on router through browser
Hi all, I bought a second hand EX8000. I performed a factory reset of the device and then did a setup of the EX8000 using the Nighthawk Android app. So far everything works great but I would like to...
- Mar 15, 2022
A reset should clear those out.
AFter the reset, try setting up using the browser and not the app.
That should let you start with the default admin/password option.
And you can customize it afterwards.
Mar 15, 2022Guru - Experienced User
Sjorrit
Mar 15, 2022Tutor
Yeah I wanted to prevent doing a factory set again. But solution works. Thanks!
