jbm701
Aug 26, 2020Aspirant
Cannot Login Using Default Username & Password following a Factory Reset
I have a PLW1000V2 that I just had to factory reset. The indication that this worked was that the SSID changed from what I had set it up as when I first installed it to now showing an SSID of "NETGEAR05_EXT." The challenge I'm having is trying to log into the mywifiext website; the default username and password, based on the documentation that came with the equipment (and many, many posts on this forum) is username: admin and password: password. Okay, fair enough. Unfortunately, for some reason, when I try to login to change the SSID back to what I had, it tells me that the username and password are incorrect. I've been working on this, no kidding, for almost 8 hours and can't figure it out.
When I first installed the PLW1000V2, I did change the admin password, but a factory reset, from what I understand, should have changed back to the default. No worries, I did try the password that I created when I first installed the equipment and received the same "wrong password" error.
Does anyone have any tips and/or tricks on how to login to the PLW1000V2 after a factory reset? I've also tried Genie and I receive the same username/password error. Any help would be very much appreciated. Thank you.
