roseandtoby
Apr 18, 2020Follower
cannot re-connect my Nighthawk X6 since getting a new modem today
Hi, Today I installed a new modum at home. So the WiFi has new name and password. When I try to re-connect the Nighthawk X6 to the new network using the Nighthawk App, I keep being told to go back...
Apr 18, 2020Guru - Experienced User
which model extender is it? (look at the label)
Firmware on the extender?
If its a mesh extender, are you setting it up in mesh mode/single ssid? if so, it uses the same ssid as the router does so there isn't a ****_ext to connect to.
