Alanwongy2k
Aug 02, 2020Tutor
Cannot reach 1gb speed
It is not able to reach 1gb speed as the attached picture, but I can reach 1gb speed when my laptop plug into the boardand modem with LAN cable. I am already using CAT6 LAN cable.
- Aug 03, 2020
Try installing version 1.0.9.42 of the firmware. Factory reset the router and then during setup, only change what's needed to get the internet working. Then speedtest.
If you're getting the full speeds, then you can start making changes and testing as you go so you know if something impacts it.
and if it works, disable auto updates.
Aug 02, 2020Guru - Experienced User
How are you testing speeds? wired? wireless? wireless won't hit 1gig speeds fyi.
What firmware is on the router?
What modem/gateway is it connected to?
Did you have qos, access control, traffic monitoring, parental controls, enabled at some point? If so, try factory resetting the router and reinstalling it with making sure those services aren't enabled.
Alanwongy2k
Aug 02, 2020Tutor
I m already using the speed test inside the nighthawk apps with wired CAT6 lan cable. The firmware version is 1.0.9.88_10.2.88. qos, access control, traffic monitoring, parental controls were off. I have also tried factory reset and reinstalled whole config, it just make it connect to wan after factory reset. However it is still cannot reach 1gb speed.
