fiorentino's avatar
fiorentino
Cannot select channels manually on AX6000 WiFi Range Extender
Hello,   I seem not to be able to set 2.4 & 5ghz channels manually in the setup of my AX6000 WiFi Range Extender (EAX80). I have manually selected the channels on my router (6 & 161), but the exten...
  • plemans's avatar
    Oct 05, 2020
    Set your 5ghz channel width back up. Again, 5ghz doesn't broadcast as far so taking up the full 80/160hz width isn't as impactful as when doing it with 2.4ghz. You'll take a significant speed hit with it set down. Not sure who gave you the info to turn it down for 5ghz. It can sometimes help with 2.4ghz but tends to help when everyone in the area does it, not just 1 person.
    And again, in extender mode, you can't select the channels for the extender. it HAS to use the channel the router is on.
    And the "optimal" channel for 5ghz isn't always the highest one. it does tend to have a little higher throughput but if you were worried about that little bit extra, you woudn't have narrowed your channel width.
    so set the 5ghz back to ull 80/160 width that your router support, and then use the lower channel.
