duane_barry
Aug 13, 2018Aspirant
Cannot set the 5GHz channel on EX3700 Range Extender
I've just purchased an AC750 WiFi Range Extender Model EX3700 and have configured it as an extender with a different SSID than the primary router. I would like to select the channel used on the 5GHz...
- Aug 13, 2018
duane_barry wrote:
I see. This makes sense. Does Netgear make any Wifi extenders with a dual 5GHz radio so?
Yes. The current list includes the
- EX7500
- EX7700
- EX8000
You use the fastlane feature to dedicate one of the 5G radios to the backhaul network, and use the other radio as client facing. Note that channels used by the two radios don't overlap (one does the lower numbered channels, the other does the higher numbered channels).
Aug 13, 2018Guru - Experienced User
When you are in extender mode, the extender needs to connect to the router, and of course that connection needs to be on the same channel that the router is using. Since the EX3700 only has one 5G radio, it needs to use the same channel for it's client-facing network.
So this amounts to a hardware limitation that is shared by most extenders.
duane_barry
- StephenBAug 13, 2018Guru - Experienced User
- EX7500
- EX7700
- EX8000
