geezer
Sep 25, 2011Aspirant
Cannot setup Canon printer with new Windows 7PC
My old PC running XP died and now have new PC running Windows 7. The old and the new PCs are wired connected to the router. Under old PC my Canon MX860 was wireless connected to NetGear624v3 router. ...
geezer
Sep 28, 2011Aspirant
jmizoguchi wrote: network key is also labeled as encryption
login the wireless devices and fetch or if you see ***** then make NEW ONE and update ALL wifi devices
Thank you for your prompt reply. Unfortunately I know almost nothing about configuring a router. I did set up this printer to a previous computer, but that's not helping me know. I open the router, but do not find words "encryption" or "fetch". I did open Attached Devices and find my iPhone (192.168.1.4) and the new PC (192.168.1.5. The first space (192.168.1.2) is blank. The second space (192.168.1.3) upon refresh shows "F6768F000000 ".
Upon second refresh, the entry F6768F000000 went away and 162.168.1.5 appeared showing blank.
Can you dumb your answer down? Or if there is a basic primer or item in the KB point me to it. I looked but don't see anything that seems to help. Of course it may be because I don't understand even basic terminology to get started.
Thanks,
geezer
