geezer
Sep 25, 2011Aspirant
Cannot setup Canon printer with new Windows 7PC
My old PC running XP died and now have new PC running Windows 7. The old and the new PCs are wired connected to the router. Under old PC my Canon MX860 was wireless connected to NetGear624v3 router. ...
geezer
Oct 03, 2011Aspirant
jmizoguchi wrote: network key is also labeled as encryption
login the wireless devices and fetch or if you see ***** then make NEW ONE and update ALL wifi devices
I have reviewed the manual as you suggested. To make sure I understand your suggestion - when I open using routerlogin.net I find on the network page in the window next to passphrase *******. If that is the place you refer to do I understand your instructions to mean that I should delete its contents and type in a new passphrase?
