jscibelli49
Apr 02, 2018Aspirant
Cannot upgrade firmware WN3000RPV3
I am trying to apply a firmware upgrade to the extender. When I try to connect to login using mywifiext.net I am getting a New Extender Setup screen. No option to login to the extender (I have upgrad...
spokes467
Apr 03, 2018Aspirant
Hi. I am having trouble logging in to my net gear for wifi to I pad
can you help. Net gear is logged in to router ok
- jvasanth1984Apr 03, 2018Virtuoso
Hi spokes467,
Try mywifiext.net when your device is connected to extender's wifi network. If it doesn't work, try to use the IP address of extender to login which you can retreive from attached devices of your router.
