KevinTichenor
Apr 17, 2020Initiate
Can't Access My Wifi Ext.net or 192.168.1.250
Flat out, I'll make this as basic as I can: I can't access the my wifi ext.net or 192.168.1.250 to login to the extender. I've tried Internet Explorer, I've tried Chrome, I've tried Firefox. E...
Epic-Hunt
Nov 05, 2023Initiate
So, my private home network is not 192.168.1.xxx. The default IP address of an extender is 192.168.1.250, SO I had to go into my computer's WiFi network settings:
Change Dynamic to Static
Set Static IP to 192.168.1.5,
Set IP Mask to 255.0.0.0
Set DNS to 8.8.8.8 for now
THEN I could get to 192.168.1.250. Once you go through the setup wizard, you will not be able to get back to the extender, so then change your computer back to a dynamic IP address, and you are good to go.
schumaku
Nov 05, 2023Guru - Experienced User
The default IP for some of these Extenders is indeed 192.168.1.250/24 to be correct. The default subnet mask is 255.255.255.0, so very similar to many home networks. The only challenge (instead of reconfiguring everything in this case) would be to find the other device using the same address, reserve a different MAC address for the other device device.
