Timbo242
Dec 10, 2021Tutor
Can't access site
I have had this extender for quite a few years and have always been able to log into my extender account using a user name and a password. Recently when I try to do this I just get a message saying ...
- Dec 13, 2021
Hi Plemans
Did the reset and reinstall and after a lot of "faffing" around with setting up new account and after a good few hours, it is all working fine!
Thanks so much for your help and patience!
Have a good Christmas
Regards
Timbo242
Timbo242
Dec 10, 2021Tutor
Hi Plemans
I was using the mywifi etc (apparently I am not allowed to type the full url address on posts?) but have now tried using the IP address for the extender as shown on connected devices on my router - still the same result. Cannot reach site.
As far as LED's are concerned - all solid green. As normal. Extender is working fine, it is just accessing my Netgear account I am having difficulty with....
Dec 11, 2021Guru - Experienced User
Is it showing as connected in your router?
- Timbo242Dec 11, 2021Tutor
Hi Plemans
Yes it is showing as a connected device on the router
Regards
Timbo 242
- plemansDec 11, 2021Guru - Experienced User
do you get to the login page when you attempt to access it or just the "page cannot display"?
Have you tried factory resetting and reinstalling the extender? (use the installation assistant if you do)
- Timbo242Dec 12, 2021Tutor
Hi Plemans
I do not get the login page - it simply goes to "can't connect to this site"
I will ty the factory reset and reinstall tomorrow - will use the install assistant.
Hopefully this will work
Thanks
Timbo242
