wussery
Mar 09, 2012Tutor
Can't Access WN3000RP mywifiext.net Page
I just purchased WN3000RP Range Extender and had no issues at all connecting it to my Netgear WNR3500 Router. I see both SSID's when I do a scan, but when I type in http://www.mywifiext.net or http://...
jmizoguchi
Aug 15, 2013Virtuoso
Make sure there is not active wifi enable on computer you are using, Disable it
Then use ethernet to the extender and try again
robertmac1
Nov 28, 2015Aspirant
have had the same problem and it took me a long time to solve it. The solution is to 1st of all make absolutely certain that the Wi-Fi is turned off on the computer and secondly I found that I actually turned off my main modem and the mywifiext then worked. Alternatively192.168.1.250 also seems to work. As soon the program comes up on the screen I was then able to turn my main modem on again. If the modem doesn't come on in time it won't have been able to make a connection in which case you have to press the refresh button to have another try. From then onwards everything is fairly straightforward
Robert MacLachlan
- cattyk76Feb 28, 2016Aspirant
I tried following what you suggested but when I typed in the web addresses suggested, it said there was no internet connection, obviously because I had turned off wifi and the main modem....
Any other suggestions? Haven't been able to add any new devices into the wifi network for a while now.
- DarrenMMar 01, 2016Sr. NETGEAR Moderator
Hello cattyk76
Are you able to connect a Ethernet cable to the WN3000Rp and they try to connect to mywifiext.net
DarrenM
