ray_boston
Oct 10, 2024Initiate
Can't access/load the admin page (N300 Range Extender)
Hi. I've got a 5-6 year old N300 range extender that has served me well. However, I can't seem to get the admin page to load. I'm on the same wi-fi network as the extender, and I've tried using both ...
- Oct 10, 2024
try logging into whatever router you have and look at its attached devices page. Use that to find the IP address for the extender and use that to connect to it.
Oct 10, 2024Guru - Experienced User
ray_boston
Thanks for that suggestion. I found the IP of the extender on my main router and I was able to log into the admin screen of the extender using that IP address. I will change the assignment of the extender from DHCP to Reserved IP so I don't have to go thru that again.
Thanks again. -Ray
