Rodrigoc
Oct 23, 2023Aspirant
Can't acess mywifiext
Good morning,<br><br>I am not able to acess the extender configuration local website by any means. Need help to rw configurate my extender after a eletric power shortage when it lost its configuration...
- Oct 23, 2023
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Oct 23, 2023Guru - Experienced User
Rodrigoc
It worked! Thank you!
